MitchScheele
- Jan 10, 2016
Mitch- looks like a keeper!,
Hope you have a Mig and can weld! ( It may sound like $$ to get set up welding yourself but it will save heaps on paying someone to do it for you).
After blasting get her primed even though you will be cutting out out sections you don't want the rust to start in again over the time it takes to repair the nasty spots.
I'd go for a 1HDFT and box out of the last Turbo'd Utes!! that will get her up and boogying!
Have fun mate she will be a little ripper when your done!
Looking good although not so good that someone's been bodging in places. There looks like parts there you might want to remove and have copied before they get blasted to bits if those roof rails are as bad as they look.
Hi it looks a lot of woke it will be good from Tony.
some things can be fixedAhem…there's nothing 'Old' about being made in '68 I'll have you know…[emoji35][emoji6]
You can go off some people…[emoji4]
What do we think? I think the 40's are the best looking vehicle Mr T ever produced. When I see them, I want to hug them as much as drive them. Sadly, never had the pleasure
IMO It looked much better rusty and green than it does shiny and blue over rust.
You have a lot of work ahead of you, but you'll end up with a beauty, and all your own work.
Great project, looking at this with interest, when you get it...
Star, any tips to look for? what parts stand out that you think i should remove and blast? cheers mate
I'm not the best to ask, and TBH its not right for me to assess something from a photo. You really need to inspect the parts clinically and methodically. I would blast all that will not be damaged on the bodywork and chassis and take the advice of your blaster and spray buddy.
You want to keep it original, which is the way to go, so repair what you can and replace what is beyond repair. Obviously anything that has rusted to the point it is losing its strength has to be removed and replaced with new metal made to fit exactly the space it needs to go not planted over the top like the previous guy has.
If you want to weld it, pop yourself on a course, get a recommended welder and practice, practice, practice (on spare metal the same thickness as the vehicle) until you get good and can work on the vehicle.
It was the roof surrounds that looked fragile but it might just be that they've got a good even coating of surface rust.
I would replace everything the previous owner has done as a matter of course looking at the state of some of the repairs.
As a builder the tolerances are half a brick, as a metal fabricator the tolerances are probably 1-2mm. [emoji4]
There's various thoughts in the programme matter but search 'Wheeler Dealers' on YouTube. The mechanic (Ed) sometimes does some bodywork and the way he welds and fabricated metal will offer some insight into what is required. There various programmes to choose from if you can view down under (you might need to turn the screen up the other way [emoji6]).
Hi Mitch,
I had a good look at the photos and, even though the previous guy has been something of an animal, you do not appear to have any unusual places for the rot which I would take as a very good sign.
Judging by the rear shots you will probably find that the rear body cross member is shot but it's repairable/replaceable.
Mud gets in between the front wings and the wing support and rots them from the inside out. We split the spot welds between the inner and outer wing and re-secured them with plates and stainless bolts so that they are easy to remove and clean. But if you are not going to use it in adverse conditions then regular cleaning will do. Also worth checking in behind the front valance as dirt accumulates there and they rot from the inside out.
If the climate is humid where you are, take the advice of the painter mate because primer is porous and standing around for a long period, even indoors, will mean stripping it off again. Maybe worth considering coating it blasted panels with Metal Ready or something similar. Several companies make floor pan repair panels.
It is a good basis by the looks of it and I shall follow your progress with interest and if I can be of help, shout up.
Hi Mitch,
Just one point from your response...
Sand blasting is very harsh and will leave 'salt' deposit on the metal, however well it is cleaned after and it can distort unsupported panels like the rear side panels. May I suggest either bead or soda blasting. Soda blasting is the kindest to the metal but takes longer but in the long term creates less cleaning work as the remnants will just wash out.
Well two...
The hardtop - using old blankets and wood supports the h/top will strap underneath the chassis between the wheels and there is space between the frame and body to get straps. Much less wind force down there - just a thought...
