BobMurphy
- Mar 1, 2010
Right Folks, I need some advice before I go and bend something
The Truck - 1998 KZJ95, Manual, 3.0 litre 1KZ-TE motor.
Two new tyres arrived today so, while the front wheels were off I thought I'd remove the rusted-out disk stone guards and fit the nice shiny ones I got from Ian Rubie. I spent a couple of days removing the siezed bolts a few months ago so I know they will be easy to remove once the hubs are out of the way.
So, with the car properly jacked under the chassis rails I removed the front O/S caliper and disk.
Then removed the dust cap.
Then the split pin and retainer.
And then the retaining nut on the end of the drive shaft. I won't go into the hassle of re-fitting a disk and wheel, lowering the car and then using a 34mm socket on a 3/4" power bar to get it off - but it wasn't very tight, 50 ft/lbs at the most, nothing like the 174 ft/lbs in the manual
Next, I thought all I had to do was draw the hub off the shaft and out of the bearing - so . . . .
However, as I hand-tightened the puller the shaft just slid back into the hub. I stopped while I had a few threads left so that I could pull it back out.
From the diagram in the Ellery Manual and from the Toyota parts diagrams there doesn't appear to be anything locking the hub into the bearing. Is this right ??
If so, and assuming I can't use the drive shaft as a fixed point for the hub puller, how does one draw off the hub ??
In the corner of the workshop I have the Grand-Daddy of all slide hammers that I bought for £30 at a Classic Vehicle Autojumble - is that the answer ???
failing that - wooden wedges behind the hub ???
Thoughts please before I go and do something I'll regret (I need the car on Sunday ).
(I could post the diagram from the Ellery manual, but that might be against the rules ).
Yours in anticipation.
Bob.
Bob.
