Right - so it's done. What a battle!! If you think you can do this without removing the front wheel, you're some kind of special midget contortionist who's also triple-jointed
The two jubilee clips that go on the inside of the unit, on the hose between the air filter housing and the snorkel don't fit - too damn small, so it's off to Halfwits tomorrow to get some bigger ones.
Also - there are 3 mounting pints for the lower part of the airfilter. When I took out the filter and had a look inside, one bolt is missing
. I wonder what the heck happened to that, and why the filter had been taken out??? So will need to get a new bolt from Mr T on Monday, or else it's not water tight, and need new mudguard clips
The rest of it fits together fine. It's a pain getting the clips out that hold the plastic mud guard liner in place, but you MUST get that off if you don't want to struggle (I struggled...). The instructions say 2 hours - forget it - took me most of the day (a lot of it spent watching paint dry ...
) Used a spray can of Hammerite Silver smooth .... next time I'll use a brush
So - before we started:
The snorkel all packed up:
Wheel off and instructions where I can see 'em:
Air filter out:
Found a spot where my tyres are rubbing ...
After much faffing, template on:
And the inner air tube out (what a schlep):
Holes drilled (ouch)
Upper support holes drilled:
Loctite sealant added to all seals (I'm paranoid):
All in place:
Wheel back on and torqued up:
Ready to rock 'n roll (almost - still got to seal and tighten the inner seals):
I'm knackered ....
Air filter out:
All in place:
I'm knackered ....
