Beau
- Jan 28, 2011
Hi guys, I have a 1kzte engine sitting in my garage for the past year and I am know beggining to strip the engine down and hopefully rebuild it.
1st thing was the head wasnt cracked ,FEW!
Anyway I am thinking of baically modifying the engine for better performance overall with out damging the life span on the engine or putting more strain on it.
I have seen some of these engines fitted with bigger turbos which obviuosly offer better torque and better performance. Does anyone know what turbos would be suitable for this engine. I will take it I will need one which will spool up at very low revs. Im thinking of a turbo off a skip truck or something along those lines. I know I will need to obviously do some mods to the exhaust manifold ect but the engines out so that will be easy. The hard part i finding the appropriate turbo which will do the job.
After stripping down the engine, the head is in very good condition along with the block, pistons ect. I think it may be a good idea to replace the rings and the valves so that I get 100% power when I am done. The camshaft is in very good condition, not too sure if it worth changing the bearings though?
If anyone else has ever done an engine rebuild I would appreciate any advice and help.
Thank you.
Thank you.
