I have them out and have some pictures but one seems so have some dirt on the back reflector so im just trying to work out how to go about cleaning it if I can.
OK, as mentioned both light work BUT on closer inspection the driver’s side light seems to have had some water in it at some time and although it is clean inside and the lens is good the reflective coating on the back of the light is 60% gone and so the light seems a little duller than the other.
Here are the pictures.
With this in mind its not fare to sell both light as 100% so if you want both you can heve them fo r£80 or if just the one then £60
