New short block, and head with the following changes: EGR blocked off, top mount intercooler. The old engine had a cracked #4 cylinder wall.
Everything was tripled checked and probably looked over the timing marks on all the timing gears about ten times over. Timing belt marks all good.
So, with a new battery, I proceeded to prime the injectors with the high pressure lines open to bleed the air out. After several attempts at starting, it sputtered. I waited as I am cautious about not burning out the starter or battery.
It started, quite a bit rough as the video shows.... Any thoughts???
Before my engine blew last year, I did have some hard starting issues even in warm weather. Could this possibly be the notorious SPILL VALVE??
