ABS light coming on intermittently??
robthebox said:
Thanks for that Bob. Are these pics of an LC 90 diff lock .....
Yes, the Actuator came from 'Pentland Cruiser's' 1999 KZJ95 Auto.
It sort of worked for a while, but the case had been damaged and when a garage tried to remove it the break became terminal.
I replaced it with a new one from Milners:
I haven't heard from Mike recently so conclude that all is well :thumbup: .
Bob.
Yep thats mine, your pics are really useful.
I will work out the best bits to drill if the heat doesnt work from your pics.
Thanks Bob
BobMurphy said:
I still have the bits from 'Pentland Cruiser's' Actuator, I'll try heating the grease and see what happens.
I'll report back :thumbup: .
Today I heated up the grease-covered gearwheel with a hot air gun; I used the 1Kw setting.
The grease softened a bit, but it wouldn't melt or go runny.
I suspect that hearing the Actuator from the outside won't cause the lubricant to flow - but it might ease the tolerances so give it a go (carefully).
Bob.
Bob, .been stuck working on my laning trooper, body mounts needed rebuilding along with front x member. Only hanbrake and cv boots left to do then Ill be back to the LC.
Thanks for your help mate.
Rgrds Rob
