[ADMIN] ELCO Weekend 17th-19th April 2009
Morning All,
Well things are shaping up nicely for the ELCO weekend at Lincomb Farm.
Thanks to the excellent work over the weekend by Tony, Toby, Ian, Ray
and Jon we now have a few more interesting obstacles on the off road
course with more changes coming over the next few days.
To date we have 12 vehicles/29 people registered.
I know there are a lot more of you that are wanting to come along, so
if you can come, please could you go across to the website and register
so that I can keep an eye on the numbers - see
http://www.landcruisers.info for more info.
We need to get a clearer idea of the numbers for the catering side of
things, and with the event being featured in the next edition of Total
Off Road magazine, if it gets to the point that we might have to
restrict numbers it would be on a 'first come first served' basis.
0845 508 6863
Ledbury, Herefordshire. UK
1994 HDJ80, 2.5" OME Lift and a few goodies.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Julian,
That message is also all garbage to me ....
Cheers,
Duncan.
2009/3/17 Julian A.R. Voelcker <[Email address removed]>
How bizarre, it seems to be some sort of encoding issue.
The message should have read...
Hi Steve,
I could make up some High Lift jacking points for you, but to be honest
you won't need them for the weekend - if you do get stuck at all
(highly unlikely unless you are trying really hard!!) there will always
be someone around to tow you out.
As for the electrics, Jon Wildsmith here has some manuals that you can
download from his site, or you can just ask here.
What are you thinking of doing with the windows? At a basic level take
the window rubbers out and give them a really good clean and then spray
with a silicone based 'dry lube'. Also consider applying fresh grease
to the winder mechanism and also strip down the switch assembly and
clean the contacts in there.
After that the next best option is to consider replacing the window
rubbers with new ones and also replace the motors.
07971 540362
0845 508 6863
Hi guys
as talking about el.windows motors-how many they are?is every door has its
own?the back windows of mine works perfect.couldn't say the same about front
ones :-(
cheers
Lubo
On Tue, Mar 17, 2009 at 6:25 PM, Julian Voelcker
> Hi Steve,
> Regards,
> Julian Voelcker
> 07971 540362
> Regards,
> Julian Voelcker
> 0845 508 6863
