Got this sent to me from a guy in the uk he done it here’s what he sent me just today ....
Hi there, First thing first you need the 1kz-t engine with bellhousing so you can fit it on your 2lt (R151F) gearbox.
Engine mounts needs to be moved back 4.5cm on the chassis.
You need kzj70 radiator.
Power steering lines.
Kzj70 air box with filter.
Wiring the alternator, oil pressure sensor, mechanical pump. Water temp sensor.
Lets not forget crankshaft oil seal with brand new clutch kit,
New custom made exhaust system.
