G'day mate I run the firestone airbags in a non cruiser , similar weight though , make sure when you fit them there is enough line to extend all the way through suspension travel full suspension +10% at least , I know this for a fact , been down that road
you can get Kevlar sleeves if needed to raise the pressure ( 35lb Max without sleeves 70lb Max with sleeves )
a very good load aid when used correctly , I use them to tow my camper , which has a fairly excessive ball weight , I have on board air so I can get to camp towing /loaded up ,unhitch /unload and reset to go 4x4
make sure the air line is cut nice and sq too
cheers Graham
