BIG clean GREEN
Ayup all,
Please help
I've got a Kenwood head unit with all sorts of fandango settings, none of the usual bass and treble settings, I've replaced the OEM speakers with 4 Vibe Fli 210w 70w RMS triaxle speakers, the midrange and volume are good but it lacks bass, so I've just took ownership of a Ground zero (GZUB800ACT) active underseat sub with built in amp, I've plumbed it all in, but because I is as thick as sh*t it sounds crap, when I play Phil Collins "in the air tonight" the drum solo was far too deep bassy and had little to no clarity ! the sub has frequency settings on the rear and also the head unit has frequency settings, I don't where to set the, high mid low ? and should the head settings match the sub?
I've used an RCA set up for the speakers and they run without an amp !
All suggestions are most welcome
Nick.
Please help
Nick.
