Geordie Paul
Here may be a very stupid post
When is the best time to check the Automatic Transmission Oil level, Hot or Cold? Mine seems to have too much in. I have always checked it when the engine is hot and the level has always been 4-5mm over the top of the hot marker on the dipstick. I tried testing it from cold today and the level was still 4-5mm over the hot marker on the dipstick
I normally check it with the gear select in N.
There is no water in there as the oil looks very clean (not white) and there is no visible water on the dipstick.
I am going to change the oils this weekend and am not sure what level to fill it back up to.
Will running it with too much oil in do any damage? It has been like this for a few thousand miles now. It was only when i checked it from cold that i thought it seemed odd. Toyota did the last service at 133K (now 140K)
Thanks for any help
Thanks for any help
