Axle breathers
------=_NextPart_001_0346_01C7E67D.06FAF900
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hi Alan,
The breather cap on the gearbox can be accessed by taking out centre the
console and unscrewing the plates around the main gearstick. Take the
gearstick out with the rubbers etc..
You will see it then below the circle and should be able to pull out it
like a tooth .
Not sure about the transfer I am afraid???
If I remember correctly the bend is quite tight, hopefully the hose you use
will flex enough.
Are you sure it's not leaking around the seal of diff? This tends to land on
the prop and spray all underneath the back of the car from one of my
experiences ;-).
Martin.
Behalf Of Alan
Sent: 24 August 2007 18:02
To: [Email address removed]
Subject: [ELCO] Axle breathers
Just to re-iterate the importance of axle breathers.
Mine were not done and I have attended a few pay and play sites, running
through some deep water/mud/sand puddles.
Well the breather pipe on my rear axle must have sucked some muddy water in
at some stage and blocked the pipe up.
After going on a long run to collect some tyres from Bristol, I was
returning down the A34 south of Newbury and found that the rear axle smelt
hot?. I pulled over to check it out and found that the axle must have heated
up and frothed the oil so much that it had actually blown the pipe off of
the axle and spread LSD oil all over the bottom of the car.
So Saturday will be spent extending the pipework up into the car so it won't
happen again.
Anyone tell me if the KZJ70 (1993 vintage) with 3.0TD (1KZT Engine) has
gearbox and /or Transfer case breathers? And if so how do I go about
accessing them?
Many thanks
Alan
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:v=3D"urn:schemas-microsoft-com:vml" xmlns:o=3D"urn:schemas-microsoft-com:office:office" xmlns:w=3D"urn:schemas-microsoft-com:office:word" xmlns:m=3D"http://schemas.microsoft.com/office/2004/12/omml" xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=3DContent-Type content=3D"text/html; charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 12 (filtered medium)">
<style>
/* Font Definitions */
@font-face
{font-family:"Cambria Math";
panose-1:2 4 5 3 5 4 6 3 2 4;}
@font-face
{font-family:Calibri;
panose-1:2 15 5 2 2 2 4 3 2 4;}
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-margin-top-alt:auto;
margin-right:0cm;
mso-margin-bottom-alt:auto;
margin-left:0cm;
font-size:12.0pt;
font-family:"Times New Roman","serif";
color:#010158;
mso-believe-normal-left:yes;}
a:link, span.MsoHyperlink
{mso-style-priority:99;
color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
color:blue;
span.EmailStyle17
{mso-style-type:personal-reply;
font-family:"Calibri","sans-serif";
color:#1F497D;}
.MsoChpDefault
{mso-style-type:export-only;
font-size:10.0pt;}
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 72.0pt 72.0pt 72.0pt;}
div.Section1
{page:Section1;}
</style>
<![if mso 9]>
<style>
p.MsoNormal
{margin-left:7.5pt;}
</style>
<![endif]><!--[if gte mso 9]><xml>
<o:shapedefaults v:ext=3D"edit" spidmax=3D"1026" />
</xml><![endif]--><!--[if gte mso 9]><xml>
<o:shapelayout v:ext=3D"edit">
<o:idmap v:ext=3D"edit" data=3D"1" />
</o:shapelayout></xml><![endif]-->
</head>
<body bgcolor=3D"#F3EDED" background=3D"cid:[email protected]"
lang=3DEN-GB link=3Dblue vlink=3Dblue style=3D'margin-left:7.5pt;margin-right:7.5pt;
margin-bottom:7.5pt;SCROLLBAR-FACE-COLOR: #c6d7ff;SCROLLBAR-HIGHLIGHT-COLOR: #ffffff;
SCROLLBAR-SHADOW-COLOR: #ffffff;SCROLLBAR-3DLIGHT-COLOR: #7b9ed6;SCROLLBAR-ARROW-COLOR: #4a6184;
SCROLLBAR-DARKSHADOW-COLOR: #bebebe;background-position-x:0%;background-position-y:
0%'>
<img src=3D"cid:[email protected]"
v:src=3D"cid:[email protected]" v:shapes=3D"_x0000_Mail" width=3D0
height=3D0 class=3Dshape style=3D'display:none;width:0;height:0'>
<div class=3DSection1>
<p class=3DMsoNormal><span style=3D'font-size:11.0pt;font-family:"Calibri","sans-serif";
color:#1F497D'>Hi Alan,<o:p></o:p></span></p>
color:#1F497D'>The breather cap on the gearbox can be accessed by taking out centre
the console and unscrewing the plates around the main gearstick. Take the gearstick
You will see it then below the circle  and should be able to pull out it like
a tooth .
color:#1F497D'>Not sure about the transfer I am afraid???<o:p></o:p></span></p>
color:#1F497D'>If I remember correctly the bend is quite tight, hopefully the
hose you use will flex enough.
Are you sure it’s not leaking around the seal of diff? This tends to land
on the prop and spray all underneath the back of the car from one of my experiences
;-).<o:p></o:p></span></p>
color:#1F497D'>Martin.
color:#1F497D'><o:p> </o:p></span></p>
<div style=3D'border:none;border-left:solid blue 1.5pt;padding:0cm 0cm 0cm 4.0pt'>
<div>
<div style=3D'border:none;border-top:solid #B5C4DF 1.0pt;padding:3.0pt 0cm 0cm 0cm'>
<p class=3DMsoNormal style=3D'margin:0cm;margin-bottom:.0001pt'><span
lang=3DEN-US style=3D'font-size:10.0pt;font-family:"Tahoma","sans-serif";
color:windowtext'>From:</span>
<span lang=3DEN-US style=3D'font-size:10.0pt;
font-family:"Tahoma","sans-serif";color:windowtext'>
[Email address removed] [mailto:[Email address removed]] On Behalf
Of
Alan
Subject: [ELCO] Axle breathers<o:p></o:p></span></p>
</div>
</div>
<p class=3DMsoNormal><o:p> </o:p></p>
<table class=3DMsoNormalTable border=3D0 cellspacing=3D0 cellpadding=3D0 width=3D"100%"
style=3D'width:100.0%'>
<tr>
<td width=3D"100%" valign=3Dtop style=3D'width:100.0%;padding:0cm 0cm 0cm 0cm'>
<div>
<p class=3DMsoNormal style=3D'margin:0cm;margin-bottom:.0001pt'>Just to
re-iterate the importance of axle breathers.<o:p></o:p></p>
</div>
<div>
<p class=3DMsoNormal style=3D'margin:0cm;margin-bottom:.0001pt'>Mine were not
done and I have attended a few pay and play sites, running through some deep
water/mud/sand puddles.<o:p></o:p></p>
</div>
<div>
<p class=3DMsoNormal style=3D'margin:0cm;margin-bottom:.0001pt'>Well the breather
pipe on my rear axle must have sucked some muddy water in at some stage and
blocked the pipe up.<o:p></o:p></p>
</div>
<div>
<p class=3DMsoNormal style=3D'margin:0cm;margin-bottom:.0001pt'>After going on a
long run to collect some tyres from Bristol, I was returning down the A34
south of Newbury and found that the rear axle smelt hot?. I pulled over to
check it out and found that the axle must have heated up and frothed the oil
so much that it had actually blown the pipe off of the axle and spread LSD
oil all over the bottom of the car.<o:p></o:p></p>
</div>
<div>
<p class=3DMsoNormal style=3D'margin:0cm;margin-bottom:.0001pt'> <o:p></o:p></p>
</div>
<div>
<p class=3DMsoNormal style=3D'margin:0cm;margin-bottom:.0001pt'>So Saturday will
be spent extending the pipework up into the car so it won't happen again.<o:p></o:p></p>
</div>
<div>
</div>
<div>
<p class=3DMsoNormal style=3D'margin:0cm;margin-bottom:.0001pt'>Anyone tell me if
the KZJ70 (1993 vintage) with 3.0TD (1KZT Engine) has gearbox and /or
Transfer case breathers? And if so how do I go about accessing them?<o:p></o:p></p>
</div>
<div>
<p class=3DMsoNormal style=3D'margin:0cm;margin-bottom:.0001pt'>Many thanks<o:p></o:p></p>
</div>
<div>
</div>
<div>
<p class=3DMsoNormal style=3D'margin:0cm;margin-bottom:.0001pt'>Alan<o:p></o:p></p>
</div>
</td>
</tr>
<tr>
<td width=3D"100%" style=3D'width:100.0%;padding:1.5pt 1.5pt 1.5pt 1.5pt'
id=3DINCREDIFOOTER>
<tr>
<td width=3D"100%" style=3D'width:100.0%;padding:0cm 0cm 0cm 0cm'></td>
<td valign=3Dbottom style=3D'padding:0cm 0cm 0cm 0cm' id=3DINCREDISOUND></td>
<td valign=3Dbottom style=3D'padding:0cm 0cm 0cm 0cm' id=3DINCREDIANIM></td>
</tr>
</table>
</td>
</tr>
</table>
style=3D'color:windowtext'><o:p> </o:p></span></p>
</div>
</div>
</body>
</html>
------=_NextPart_001_0346_01C7E67D.06FAF900--
