bars (80)
Hi Guys
There are two bars just under the radiator that are on bushes either side what are these for and should they move very easly when you pull on them. The reason im asking is wheil under there I put my hand up to one of them and they moved in a small rolling movement.
John C
92HDJ 80 1HDT ireland
Hi John,
I suspect that you are referring to the track rod arm that runs from an
arm coming from the steering box near the drivers side wheel to the
knuckle on the passenger side?
This will rotate a little due to movement in the ball joints on the
end. If you have excessive movement or loseness in the ball joints
(usually caused by deteriation in the rubbers) then they will need
replacing.
Mobile: 07971 540362
1994 HDJ80, 2.5" OME Lift
Hi John,
replacing.
