- May 13, 2014
I was careful to put the magnets back in temporarily and mark them up so they went back in the same way ...........
Having scraped off all the old glue, I re-glued them back using the witness marks as a means to position them correctly.
The pins for testing the operation are the same as those for the rear locker as described above, i.e. pins 3 and 2 on the row where there is an empty slot. To rotate the other way, simply reverse the polarity.
The FSM says use a 1.5v battery and heater relay, but to be honest you don't really need to do this, you can connect a 12v battery direct if you are careful. Pleased to say the motor works fine
. What with this and the rear locker revived, I've saved nigh on a grand for new replacements
