Big brake conversion
stumog
I need to change my front discs and pads soon. now i have a 91 with the smaller discs. has anybody changed to the later set up before if so what parts are required please.
i would have thought it would be discs and pads and calipers.
but do the calipers bolt straight on? do i need to change cvs and stub axles?
is there any point in doing the conversion ? the brakes i would just like a bit more power in them. any ideas would be welcome.
stu
You may also need 16 wheels too.?
Sent from my GT-I9100P using Tapatalk 4
sorry forgot to say i am running 16"at the mo.
stu
I've done the conversion. Front bolt straight up but rear requires the bell housing too IIRC. You don't need to change CVs or stub axles.
thanks lorin so all i would need to buy is discs pads and calipers? not to fussed about the rears at the mo.
stu
IIRC the handbrake components are different as the handbrake drum is bigger (as the disc is).
Andy
at the moment only really thinking of the fronts. may ne if i dont get better brakes i would do the rears.
stu
