Hi there Bob
Yes with all four wheels/tyres on the ground
Perhaps I was not so clear
Forgetting all of the other possible causes of the clonk that I feel I've eliminated so far bushes, CV's, bearings, UJ's etc.
When she is sat with the gearbox in Neutral & the transfer box in 4H (normal everyday tarmac driving position) & all four tyres are in contact with the ground it is not possible to turn the rear prop shaft more than perhaps a twentieth of one whole turn back & fourth, maybe even less. I would consider this to be the norm. As you say Bob with the gearbox in Neutral it is the back lash in the diff that's the limiting factor only allowing such a small amount of rotation in the rear prop shaft. Fierys front prop on the other hand, has a little over a quarter of a turn of rotation in it before something limits the rotation
Now when I put Fiery into first gear with the transfer box still in 4H I then get only as much play in the front prop as I do the rear before putting her into gear.
Does this make better sense
In my head this points more towards a fault with the diff than the transfer-box/gearbox, what do you think
I really need to get that darn drain plug out & see if there are any teeth stuck to it
