Iwan
- Mar 28, 2011
Cheers mate! Just checking! Lol
Progress is steady had a good day yesterday and plumbed in the new brake lines, have been lucky that the original Billstein yellow shocks still fit with whats going on... cleaned them up and now painted up with ford blue! I believe that they're the same as the old man emu counterpart.... on a side note I'm not very happy at all with the "dirty hardware" that's gone back in! So def going to revisit this..
A few days before I got the other side sill patch in ... and happy with that, but still a little bit more needed!
I got my gearbox parts in this morning! Nice to say the least! Main shaft made by "Seamaster TAIYO KIKO MFG ltd" (labeled as terrain tamer) Same maker as the hzj75 input shaft. The long spline transfer input.... great upgrade!
Factory hj60 setup.
Not many words to say, but much stronger!
So this is the mission and subject.. Have watched a few youtube vids to prime me into this job. From what I've seen so far is they're quite a hard nut to break into! Have seen a guy angle grinding the inner bearing centre to get the shafts out so have to keep that in mind!
I was looking into thin jaw pullers and managed to buy these 3 Sykes Pickavant 217 legs. They fit in the circlip slot on this 80 series bearing.. So provided I can run them/pull on them. I'm reasonably confident that I can get the bearings out without having to cut the centre of the bearing!
I'll add some pic's of my findings!
Factory hj60 setup.
