MisterCruiser
- May 28, 2014
Black smoke when accelerating, bumper starting to turn black above tail pipe and fumes from oil filler and dipstick when warm. Checked when cold and first started and no smoke from oil filler or dipstick. However after a run and warmed up there is a lot of fumes from both the dipstick and the oil filler. Can the injector washers if leaking allow combustion gases into the rocker cover and crankcase system?
Egr, Intake mani and throttle body I cleaned fully 3000 miles ago and oil pick-up was clean too.
I also had to top it up by a litre of oil after about 3000 miles. I'm monitoring the oil level now too more accurately to see if it's burning it. The exhaust is dry black soot, not oily soot. What else can cause black smoke on acceleration and on steep hills?
