Gents, greetings from the South of Kenya where life is good..
We've had quite a few knocks but worked through them all. Thanks a lot for updating Andrew. The roads have been shocking (really!!!) and since addis where I replaced the brake disc nicely, we have completed 1100 odd kms of the hardest dirt roads in the world. The infamous stretch from northern Kenya was a killer - you won't believe the photos...
Before that through, the fuel tank straps broke off again so it was back to ratchet straps
they held the moyale road though some how. I'll get a new weld in Kampala. The fuel gauge also stopped working
looked at the connectors etc using the FSM but I think the ball valve inside the tank must have fallen off? Any ideas welcome. We lost a control arm bolt on the bad bad road which was rather alarming. The police helped out with a mostly correctly fitting one luckily
we had our spare wheel stolen? Fell off? So that's another thing to get. A bolt AND the big washer on top if the front right shock came off - but the nyloc was still on, luckily I brought spares.. the rack punched some dents on the rails after a hard brake and the brackets will be bent back better today, holding though..
We almost lost a mud flap but it's cable tied on nicely now.
Been using a lot of water during the long hot drives, like 1 litre + per day but much better now that we're on more normal roads. Tyres look like they've been through a wood chipper after the long toad
it really hurts taking your truck on these "roads". They're so bad that only trucks are allowed on them, no cars, mini buses or buses. Makes you wonder doesn't it! The cyrix rattled to pieces and is now on my manual "stick a wood block in it after starting" mode but it allows the current through. Alas the inverter gave up yesterday after being coated in dust (that's today's task). I'll take it apart again and hopefully it'll fire up cause we're pretty dependent on it.
Did an engine oil and ATF change in addis which helped us pn the hills. The ATF light's been coming on a lot where we climb 1500 metres in 15 minutes so taking it easy. Also changed the diff oil and found some filings in the rear one!? I'm guessing the plug is magnetised and catches the bits? Looks ok though (pls shout if this a critical). Almost forgot the mew brake discs and brake service was a breeze (compared to splitting the sump lol!) thanks there Ian and Jon. Also Gav, those bolts were a life saver!!!!!!
So yes, many things happen on these roads and the above makes it sound all rather simple
We've overcome all of the bits within minutes by having the correct parts or a good fix using some creative thinking - a credit to you all for your help once again.
Right now I'm lying in the tent listening to the fish eagles cry after a lovely dinner last night, eaten off a plate with knives and a fork (from the same set). We will, absolutely, upload the blog up to Sudan and then rather post photos of the other countries.. It takes a lot of time writing it all up
So it's the easy road down now with camp site to camp site driving, shorter distances and better surfaces + plenty scuba diving so we're in good spirits!!
Will be in touch soon
Please send us any messages / texts etc, all very much appreciated
Matt and team
