Steve H
- May 22, 2010
Just started getting my Collie ready for the M O T and was checking brakes , etc as you do. I noticed that the rear pads are worn out but the front ones are hardly worn at all. This cant be right can it? I thought the front should wear out quicker than the back ones. This will be my second set of rears fitted since the front pads. What do you think, rear load valve stuck open or needs adjusting? Brakes seem to be working great and truck doesn't pull to one side under braking at all.
