Well we've tried several caravans, a trailer tent, a roof tent and next to try would be a recently purchased Oz tent for our holidays but so far we haven't found our ideal set up. So my next idea is to combine a desire to build a trailer with our holiday needs and the collection of gear we've got and build my own take on a trailer tent
It won't be an all out 'adventure' trailer but I hope to design it in a way that means it could be should the need arrise or I stay interested in it long enough for that
So far I have an indispension type 1300Kg axle with braked hubs with a 5x150 stud pattern which arrived today and lots of ideas!
I have enough wheels and tyres for it to run the same as my 100 (18" OEM alloys with 285x75x18 Toyo Open Country AT's) so the trailer will have good ground clearance and run at a similar height to the tow vehicle. Rather than a fancy hitch that has lots of DOF I will use an ordinary ball hitch but a bolt on unit so it could be changed.
My idea is to make the top deck area 2400mm long by 1500mm wide (or maybe a bit wider) so it can carry our (wide) Maggiolina RT slightly offset to one side with the Fox wing awning mounted down the other side. When open the top of the Maggiolina needs to be about 1900mm high because the plan is to stand our Oz tent RV4 (with delux front
) against the side of the trailer so the Oz tent gives the living space and the Maggiolina a nice bed! The Fox wing would be raised up on poles to match and give some extra covered living space. The main idea is to have a suitable trailer to mount all these on but still be able to stick them on the 100 for solo trips.
Phase 1 will just be to build the platform for those things to be mounted on and towed. If that works out and seems like we might use it then I'll get into water tanks, gas, heaters, slide out kitchens etc but for now I need to keep it simple for there to be any hope of finishing it any time soon!
Don't expect any imediate updates because I'm in the middle of some other projects at the moment!
