Hi all
As Andrew mentioned, there has been progress on the gearbox front - but not all good I'm afraid..
I haven't called KSM (the guys who did the diagnosis and fitted the parts) but I think it's very safe to say that all is not well with the truck unfortunately. To be frank, I'm rather annoyed after shelling almost £500 for this job which is way more than any work done to date on the truck. Paid for work which amounts to just one thing which was getting the fuel tank re-fitted which was something I couldn't do. Every other thing I've done with help from one of ya
of myself..
Symptoms a few weeks ago were :
Car would not pull off without really revving for a while as it took of sllloooowly (Jon mentioned this was not good to do so I've only done it once I think luckily)
If you engaged Reverse and then drive it pulled off 100%
Gearing while driving was odd - the truck wouldn't get in to "overdrive" / the high gear and always felt like it was revving higher than it should have been
I figured out pretty quickly how to work around this ie rev it a bit and then ease off and it figured it out and stepped up in to the high gear and the turbo engaged properly and I could feel the boost
Since then, I had the 2 solenoids replaced and the wiring loom. I was at work up to the last minute and my friend took it in to get it done so we don't have any info other than that the parts were fitted and a full ATF flush done (which I was going to do anyway)
Japie (trip team member) couldn't start the truck on that day so the pumped the fuel line a couple times and it was fine for the rest of the afternoon and evening while we packed. Started her up Saturday morning and headed out but after about 800metres, I could feel it wanting more fuel / shuddering so I adjusted the fuel pump with the 6mm socket up a tiny bit and it got better. But.
* Seems like there are 2 problems now btw *
I wasn't able to get the truck to drive faster than 30mph, regardless of the amount of revving. In fact, easing right back to what felt like a very little allowed the gearbox? to figure out what was going on and gradually speed up.
As said, I think I had 2 issues at this point in time and after chatting to Andy P, agreed it was fuel related and to give it good drive to clear it out. It hasn't been driven more than 20 miles in aaaages. Things did improve and I managed, through figuring out how to drive it, to get her up to 50 and then 60mph. This allowed us to just make the ferry which is why I was stressing!
The truck is now loaded for the trip though but it's not nearly as heavy as others I've driven - it is carrying lots more than normal though
The other major issue is that I will be cruising along at 55 - 60mph, bang on 2000rpm with no issues until I hit the slightest incline. That's pretty much tickets for it.
I make sure that I keep revving delicately so that it keeps in the high gear and go as far up as I can. At some point though it just gears down to 2nd? and no matter how much or little I rev, it doesn't go faster or slower - the revs go up, but there is zero increased power
She usually lurches forward if I rev like a racing driver so I'm sure the awful wind resistance box I have on the top and the weight isn't helping but I find it hard to believe a 4.2l engine would literally run out of steam.. It's the equivalent of driving a 1.3l car at full pace and when you come up to hills, it gradually slows down and then speeds back up as you near the top. In this case you can see the directly relation of the extra hill angle using more of the power..
So, we caught the ferry and drove all the way to Switzerland with the same scenario which is now :
Cannot pull off most times from the first start in the morning in Drive, I need reverse. Subsequent pull offs are ok in Drive
The gearing is off and still often feels like I'm always a gear lower than the very rocket like overdrive gear usually engaged on the motor way
Hills immediately give the above reaction
I will check the fuel line as soon as it's a) not pitch dark, b) not snowing or raining hard, c) warm enough to do so, d) I can get to my sockets which are neatly packed at the back!
If there is a fuel blockage though, most of it must have blown through? as I am able to get up to 60mpg where before it was 30
I'm far more concerned about the gearing as the diagnosis machine at KSM said that "it needed the solenoids and wiring loom replaced" which has been done. I assume they wouldn't have let it out of the door knowing there was a fault but.. They're great guys so I'm hoping..
That's about as much info as I can give right now. I have to shoot off now but will get back online later on tonight. Hopefully tomorrow as well..
Any suggestions very very much appreciated
And expect more questions as always
And any more info in situations you have please fire away...
Thanks guys
Matt
