denjil
- Oct 18, 2014
Hi all,
Is there a modification that can be done to increase the maximum caster setting?
After fitting 2 inch lift to my swb I went for a wheel alignment.. Toe and camber have been set.. but when we tried to set the caster over a certain amount the camber would loose the correct setting as well.
I do not know if this is normal since its lifted now.
thanks
Daniel
thanks
Daniel
