Hello folks,
Ive searched and read a couple of decent write-ups on changing the clutch from underneath, without removing the engine - in particular the unfortunate one where the OP dinted the spring plate and had to re-run the whole nightmare again...
Ive got the gearbox jack trolley jig thing, all the super long wobble bars and the patience... but i cant seem to find out exactly how to remove the transfer box.
Maybe its just a straightforward prop shafts off, selector stick remove and a ring of bolts, but is there anything to watch for?
Is there anything other than a splined shaft or are there any hidden internals that will either drop off or need releasing etc.
My clutch is nearing 180'000 miles believe it or not, and after 7 years of owning the 80, its had a rumbly release bearing (or possibly spigot bearing) the whole time and never got worse.
Its not slipped yet, but when cold, its very notchy gearchanging plus needs to be stood still if selecting first.... that tells me the plates barely separating (?).
Plan is to remove the transfer, remove the radiator fan, let go of the main box, tip it down at the back, twist and hopefully wrestle it backwards like some kind of contorted charles atlas..
Hopefully im not asking a really daft question or missed a superb write-up, but any help is appreciated.
