Colorado. 90 bellhousing
tonytoyota
Hi can you help r the bel lhousing on manual and automatic the same thanks a lot on Colorado
Hi Tony.. The manual bell housing can be unbolted from the manual box but not sure if the auto b h is part of the auto case?
If you have a h55f with the 2h bell housing, could you use the part of the auto 1kz where the starter mounts and cut in a certain place and amalgamate it on to the 2h cut of the h55f bell housing, with carefull measuring and an ally tig welder (a guy in Oswestry can do this) then you could retain and use the h55f and propshafts etc.
Interesting idea! :thumbup:
Hi Iwan thanks I am thinking of putting A Toyota hilux surf 4 runner manual gear box in and I was thinking. Will the bel lhousing of my automatic fit . Wot r your think of that .
Well it won't have a hole for the clutch fork to begin with Tony.
