After having my car for a couple of days I've noticed a couple things that seem to not function
ECT Button and Overdrive buttons don't light up on odometer after clicking them
The inside of the engine has a hole where there probably was a snorkel but I'm unsure if that's supposed to be left open
Speedometer needle is accurate but slightly shaky
Fuel needle takes forever to move after a full tank
Battery needle shaking constantly
I'm able able to move 4x4 handle but I don't know if it's the H or L setting
Unsure what the hole is by the ignition switch
Light inside the key turn is always on
Top door latch of the rear door doesn't work
Car shakes while idle and shakes less when riding on idle up button
Also what tools should I get? And what fluids should I flush? And what other parts of the car should I inspect both within the engine and under the car?
