The links John offers certainly give pause for thought
IIRC i fitted the 3" exhaust first which sort of freed the engine , it's hard to explain but anyone who has ever de-restricted a 2 stroke bike will have a fair idea of what i mean . This gave far more grunt and much less engine braking but i felt the truck ran out of power long before it should , revs would keep climbing without much effect on the speedo .
I then added the IC and the problem got worse changing up a gear at 2500rpm was mandatory even in top gear , so i turned up the fuel and it improved things somewhat but i still felt something wasn't right . So i swapped the air filter for a K&N high flow and bingo . I'm tired of telling the mrs who drives everything else like a little old lady that i would much prefer it if she would change gear before hitting 4000rpm !
Still the info in the links do alarm me . Timing belt was changed and injectors checked by mr T shortly before i started modifying , every 6 months or so i chuck a bottle of Wynns diesel gold injector and fuel system cleaner in the tank .
I have never seen my temperature gauge move more than 1mm above its usual spot and it only does that only long journeys which include a spell of speeds over 70 , and even then it only happens when i've turned the fuel down so start up smoke doesn't blacken my trailer which i park next to (side exit exhaust) . With the fuel turned up shes still pulling at 100 and no temperature issues though for obvious reasons that was a short test .
Does it sound like i have fuel delivery problems ?
