Guys, the current Mrs Chris came home today in her 55 plate Corolla saying that the water trap light came on followed a little while later by the battery light.
OK. Took alternator off, pulled brushes (very neat little unit) cleaned put back. Fuel filter off, drained put back primed engine running fine. Volts across battery 12.22v Water light still on, pulled the sensor connection light STILL on. Tried googling various combinations but no hits for those lights being on together.
She can take mine tomorrow, but any ideas at all - anything in the backs of your minds? I don't want to have to buy regulator unit if I don't need one. Probably stupid money
Any simple tests that I can do? I have pulled every fuse out and inspected it with a torch. Can't find any duff ones and everything else seems to be working. Battery indicator is still showing green in the sight glass. Belt is fine. Connections fine (cleaned) I can't find the engine earth strap though. So tomorrow I might run a quick bypass on that to the battery. It's in generally all round very good condition, clean, no rust, corrosion and no history of any kind of electrical problems.
Chris and Mrs Chris
Chris and Mrs Chris
