As it says, i want to fit one on mine but would like to put a genuine one in if possible, was it ever factory fitted?
Whereabouts is the high level light sited? I've got a '94 UK model with no high level lightScott said:My 94 UK model has a high level brake light, but I do know that the previous owner installed it, he said its the same one as fitted to a 100 series. It looks like it should be there as apposed to an after market add on, that looks out of place.
Scott.
Scott posted that his '94 UK had one, I've got one of those stick-on LED jobbies but I thought if there was an OEM one it would look betteradrianr said:HI chas dont think the uk had them - my imports did, uk ones i have did not ( I think!!). it would be at the top of the back window - so on yours for the average motorist they would need a periscope to see it![]()
It's sited at the top of the top tailgate window, shining through the glass.Cossack said:Whereabouts is the high level light sited? I've got a '94 UK model with no high level light![]()
Chas
The tailgate is prone to condensation on the metal, inside the plastic. Check the earth point in the tailgate or the one under the roof lining as it will probably be one of these at fault. Either that or the cable has broke in the bendy bit where the wire goes from the car into the tailgate itself.amandrew325 said:How do you fix the third brake light? What causes the problem. Checked out the fuses, and fuse box under hood, no signs. Anyone have any ideas on what else should i check?
____________________________
"If everything comes your way, you are in the wrong lane"
OEM Brush guard, Magnaflow 22" with Gibson pipes, PRG Mini-lift, Third Brake Lights, Cooper Discoverer S/T 35x12.50x17, Lund hood protector, Ventshade in-channel window visors, Bushwacker Extenda-flares, front window tint.
Martinwhereisgibson said:Hmmn I have a high level light on mine and pretty sure it's a UK model. 80 'Amazon'. Want pics etc?
Ah cheers for that. Looking at the V5 I've got 17 characters: JT111TJ[10 numbers], first registered 1997. So looks to be a UK model?Ecky Thump said:Martinwhereisgibson said:Hmmn I have a high level light on mine and pretty sure it's a UK model. 80 'Amazon'. Want pics etc?
Easiest way to check if import or not is your VIN number.
Mine starts HDJ81 with the one denoting Jap market. The whole number is 12 characters but on a UK spec it is either 15 or 17 characters, can't remember which.
