Trevor
- Jul 25, 2010
I have a leak from the end of the timer spindle. Looking around the web I can't quite be confident what I'm reading as some folk say this is the ACSD and remove it pronto (I believe the ACSD has the 2 coolant pipes running to it).
Toyo shows this as a timer thingymabob which is at the end of the dotted lines in the pic below with the inner O ring numbered 22193. So do I remove this and blank off (any advantage or disadvantage in doing this? Or just remove and change 2 O rings, again anything that might trip me up on this?
Injection Pumps are not my area of expertise so some guidance would be most welcomed.
