It does 2 batts read bold below taken from spec sheet on the right
Battery Status At A Glance
Defining the amount of energy available in a battery is a complex task since battery age, discharge current and
temperature all influence the actual battery capacity. High performance measuring circuits, along with complex
software algorithms, are used to exactly determine the remaining battery capacity. A new shunt selection feature
enables the LinkPRO and LinkLITE to measure currents up to 10,000 and 1,000 amps respectively.
The LinkPRO and LinkLITE selectively displays voltage, charge and discharge current, consumed amphours,
remaining battery capacity and the LinkPRO also displays the time remaining of your battery bank. Using a clear
backlit LCD Display and an intuitive user interface, all parameters can be recalled with just a button press. A
second battery input is also provided to monitor voltage on a second battery bank.
The LinkPRO and LinkLITE are equipped with an internal programmable alarm relay, to run a generator when
needed or to turn off devices when the battery voltage exceeds programmable boundaries.
Performance Features
Read your battery bank like a fuel gauge
Provides critical information about the status of your battery bank
Displays voltage, current, consumed amphours and remaining battery capacity
Secondary battery bank voltage monitoring
Auto sensing battery voltage inputs
Large backlit LCD Display
Quick nut mounting construction
Programmable alarm relay
Shunt selection capability enables flexible system integration
Splash proof frontpanel
500 Amp shunt included
CE and e-mark certified
LinkPRO Additional Performance Features
Displays time remaining
Communication/expansion port
Stores a wide range of history events in internal memory
Advanced programmable alarm relay
Battery temperature sensor input
