tony rodaway
- Aug 28, 2016
petrol ? which vid did you find ?
Some one with a 2.5 straight exhaust revving the bollocks out of it.
Got it from the link u sent me and was a youtube clip.
Exhaust sound comparison
Beau's truck with only the front end exhaust with no mufflers etc(it should be noted Beau's exhaust is work in progress)
My truck with a 3" Prospeed exhaust View attachment 82410
Will someone with a standard exhaust please post a similar vid .
Ah that's Beau's 1kz with only half an exhaust when he was playing with the idea of making his own exhaust , the other vids on that thread are my truck .
The needle being just below horizontal is normal i would say , I have no idea how quickly it gets there but its usually about 5 minutes before its warm enough to work the heater in my truck . If your needle drops a little when you put your foot down i would guess you have crap sandwiched between the aircon condensor and the rad blocking airflow .
Your turbo is oil and water cooled , oil is fed by a 1" diameter (approx) metal pipe and the water an 8 maybe 10mm pipe . I was assuming your "turbo leak" was in the 2" approx diameter pipe that comes up vertical from the turbo ? if so that carries nothing but air .
To see your turbo get under the truck - your exhaust is bolted to it .
LMy turbo came out and got replaced for no reason other than because i jumped the gun and that's exactly what i fear you will do .
Turbo failure on these is rare , in fact my profile says i've been a member of this forum since Feb 2013 and i can't recall any 90 series turbo failures .
Let me get this straight - i posted a random youtube vid showing the noise created by some guy who forgot to reconnect a sensor , that guy turned out to be you . You plugged the sensor in and noise reduced but the same noise continues at a lower volume . Is that correct ?
You didn't put all the heat shield bolts back in , one holds a metal bracket for your crankcase breather pipe and i suppose that could make a right old racket if it was tapping against the shield .
Also when i split that crank breather pipe it sounded like my turbo was about to explode but only when i reached max boost .
See those shiny double pipes in my removed turbo pic , they are the turbo's only oil feed . The big 2" pipe carries only air , it gets wet with oil because the crank breather vents into the air feed before the turbo , and it only does that "to save the planet"
