Engine light on vsc track on vsc off light no power..
mrjet400
italy
Hi I have Hdj 1DHFTE 2004 I have this problem
Engine light on and after 2 sec on vcs track and off also and, the engine goes in recovery no power..
I checked the error
and code p 1121
Can you help me?
Massimo
Clean the contacts and condition of all the plugs/sockets on the throttle body and accelerator pedal.
Thank you
I'll let you know as soon as possible
I must clean also the ECU contact ?
Ciao Max
You could do but I should not do too many things at once. if the above fails you could then clean the ecu contacts if you can get to them.
Frank, thank you for your support.
I think I've fixed it. The engine now run well and the problem looks like has been resolved.
Ciao Max
