studentsoverlanding
- May 22, 2011
Re: Engine will not start after injectionpump seal replaceme
Hey Dave,
the smoking is sorted out. We fiddled around a bit with pump timing which sorted it. Ran beautifully afterwards. For about 3 hours. Then it decided to mock us again. Turned out that the small half-circle key in the injector pump axle got a bit damaged while working on it. So, went to the shop and got a new one, put it in and 1st try was a good start with perfect smooth idle. Problem solved. Also took care of leaking Rocker cover (changed seal), so engine stays bone-dry now
Gave her a good clean as well so looks way better! Now only to solve a new problem (see new post) and find a suitable route...Have heard some positive stories about syria, but not of overlanders, and have no idea about the borders with Turkey and Jordan. We were tipped about a ferry from greece, which turned out to be suspended for 10 years already. There might be a possibility from Turkey we are now investigating. When are you planning to be around syria (if you're going that way that is...)
Cheers!
Hey Dave,
Cheers!
