Lorin
- Mar 28, 2010
The trailer is a Challenger Bundu Basher, made in South Africa. It is essentially a copy of the Venter Bushbaby. As standard mine was the unbraked version with a Tare of approx 500kg (based on Bushbaby specs) and a GVM of 750kg. Unfortunately Challenger have gone bust, so there isn't much info to be found. However, I do know that a braked version was also available with a GVM of 1500kg, the only difference being the axle and the braking system, and I wanted mine to be braked....., and on 37s.
Here's how it was in standard trim when I bought it (thanks Stu)
Establishing 37s don't fit...
After much cutting, fabricating, swearing and spending.... 37s do fit
And here it is proper. 37 XZLs to match the truck. Lots of strengthening and bracing. Braked axle rated to 1600kg with same track width as the 80. New suspension leafs rated to 1200kg (maximum I will ever carry) with uprated/stronger hangers. Extended drawbar.
The next stages include mounting the tent on a lifting rack and fitting out the inside. Updates to follow.
