In the guide for the operation of the front difflock it says "When the lock control switch is switched to the front locker the power goes to terminal 6 of the difflock ECU which happens. The next sentence says ' If the limit SW on the lock inside the front difflock control motor is on at this time, until the limit SW is turned off, the current flows to terminal 8 (get that) to terminal 7 (don't get that) to terminal 3 of the front difflock control motor (don't get that). The man from Toyota did not understand the last sentence either. What do they mean?
I have tried two ECU's they both produce the same result. Assistance would be appreciated
John
John
