Yes I see. I would probably feel the same TBH. If it has resurrected itself with all that shaking, I doubt it's a loose wire. I'm 90% certain its your sender for whatever reason and it's probably not that it's stuck either.
That's where my mind is set Rich, so I'll source a replacement sender unit and hope for the best.
My other problem is the electrics on the truck in general. Years ago, I had a burn-out from front to back, well I think it was from the back to the front, but that makes no difference when you see melted looms. It actually caught fire in the rear quarter of the truck behind the plastic interior panels.
Since then, I've had wiring "repairs" done all over the place, and short of replacing the whole set of harnesses (nightmare) whenever anything fails (such as this gauge) I'm thinking its a melted insulation somewhere behind the dash.
Inevitably, and with no acumen for lectrics whatsoever, I've lost all trust in anything electrical on my truck. It's a damn shame.
Anyway, we plod on with this in mind, slowly I've managed to get (almost) everything working as it should, but the trust has gone.
As an example, I had a strange phenomenon with the door switches and interior lights. Only the passenger front door operated the front light and only the driver's side rear door operated the rear light. I checked the switches and they all worked fine on a meter. Also, the warning tone (telling you the lights are on when the ignition is off) stopped working.
Needless to say, I gave up.
At the last visit to the body repair shop, a guy there said he'd try to fix it, and in all fairness he did. Ureka! Open the door, the light comes on, all doors, all interior lights, yippee! And the warning tone now works, so I won't be leaving my lights on by mistake, again.
But, and there always seems to be a "but" when all the doors are closed, there's a tiny leak somewhere, showing the front interior roof light (the middle one of the three) with a faint glow. You can only see it in the dark, but there's a drain there for sure. I have no idea how to investigate that or what to do about it. So that light is switched off manually now, I only use it manually when needed.
The joys of an old truck, it seems, don't we just love 'em?
