Hard cornering freaked me right out!
Still miss behaving so the in next couple of weeks I will be fitting the standard springs back in.
As I understand things if the traction control is kicking in it will be spinning a wheel, 120's will not spin a wheel at 30mph on tarmac on a not so tight corner. Unless there are some sort of sensors that can tell how much body roll there is. I am going off this pos!
You have a lift ?
As ive said i know sod all about traction control but i'm thinking the brake load sensing valve might be confusing the computer because of the lift ?
I have never tried it Karl as I have only had it really on the road since Monday.
Not really Shayne, the back is still sitting high in my opinion even though the springs all round are standard height Pedders and I had fitted a 10mm spacer on the top of the front spring which did raze the front about 40mm to try and level it up. I know I know you are going to say that is my problem and that may be the case..
I wouldn't mind one weird non sensical problem but with it having two is a pain.
I consider myself competent at messing with things in the past, 205 Mi16 conversion before you could buy a kit, V8 in an Anglia 105e , 2.0 XE in a Chevette then a Honda S2000 on throttle bodies in a Chevette rally prepped . Standard Land cruiser is harder than all my conversions in the past to get my head around.
Obviously if it locked on that will cause you traction problems going around corners, hence the Q!
Don't know if its possible for these things to be in a partially locked position? (Bob?)
Could well be the Pedders , I'm not sure about the 120 but most feel they are to hard for the 90 series .
I liked them on my 90 because i could feel the road , feel when things got skittish . Reminded me of my bike days when nobbly not for road use tyres made things interesting at 70+ :icon-biggrin:
Its easy to imagine the same could cause havoc for traction control . Ask Pedders for advice maybe .
What is the best way of seeing if the centre diff is disengaging?
Shayne I spoke to Pedders about the 70's drag car look and they just kind sort of said hmm don't know. I will swap them over to standard ones once I get them blasted and powder coated just in case I have to leave them on and they won't look scabby .
Liked the drag car look so was gutted when parked up fully loaded and abandoned for few days i returned to find the springs had compressed and were staying that way after i unloaded .
We have a Pedders +2" lift on the 80 and I've been pretty happy with it - certainly never had any concerns about how it handles. Diffs being locked in sounds possible, but I'm no expert on the 120. Quick way to check is to drive around a gravel car park on full lock - if the diffs locking up it'll push you wide. Try switching the lock in and out and see if it behaves any differently?
I was talking to my mate about said problem and I just presumed it wasn't worth mentioning as I didn't think it would matter. I had fitted a new ABS sensor, my mate thinks that with the tolerances with sensors and the pickup there maybe a problem. He said rust could be affecting things, slight height differences, he suggest doing the live thing with the Snapon machine to see what is going on. I may give it to him to have a look at soon.
If you put the centre diff lock in and drive slowly in reverse on tarmac put the steering into full lock you will feel the resistance almost as if the steering is heavier, when you disengage the diff lock, and repeat, you will easily feel that it has disengaged.
I was talking to a guy I know locally who had a similar problem, he fitted a new rack to his Hilux and it did the ABS Traction control thing mid corner to him too. I have fitted a new rack and moved the steering wheel a few splines and I think that might be my problem. I have never ever heard of there being an issue when fitting a new rack before or ever had this issue myself and I have fitted a good few racks over the years. My Snapon machine doesn't seam to have to have a reset for the centring the steering wheel so I am one step closer. We will have to see next week to see if my mate can figure it out.
just reading this after my post, my traction control kicked in randomly and very severely pulling the vehicle across the road at normal driving speed on a sweeping bend. Dangerous and frightening,
I see on google that the yaw sensor can fail in this manner very rarely. I am seeking advice to disconnect it as we speak and good riddance to it too!
Just found this bones .
I had the similar VSC issues with my 05 GX. Bit of a story behind it. Not long after i bought the vehicle 2nd hand from the local automark dealer, i noticed a rattle from within the steering column. Took it to so-called steering and suspension specialists in PMB, who failed to sort it out, eventually purchased a new steering shaft, which required removal of the steering wheel. Thats when the problems with the VSC started. The Prados have a "yaw" sensor in the steering wheel, it sits behind the airbag. The yaw sensor is the device that figures out the car is in a skid, and applies the brakes selectively to prevent the skid (left front, right rear etc). If the steering wheel is removed from the shaft, and not replaced EXACTLY as it was previously aligned, the yaw sensor can go out of alignment. What i guess happens then is that as soon as the vehicle is in a particular situation , i.e. turning slightly, braking etc, the out of alignment yaw sensor thinks that the car is in an exaggerated skid, and starts applying the selective braking through the VSC system. Eventually, after many trips to the local Toyota dealer, whose mechanic had no clue (it even locked up the brakes when he was driving it), i parked it on a level piece of ground, wheels straight ahead, disconnected the battery, took off the steering wheel, re-aligned the yaw sensor with Top dead centre, then re-connected the battery. This then re-calibrates the yaw sensor. Since then i have had no more VSC problems. We know the VSC works as we often drive on a muddy road in summer, resulting in the odd bit of drift, which the VSC sorts out very quickly.
i dont know if this is the AA recommended way of sorting it out, but it worked for me.
