How has your brake pedal been? Worn bearings allow the hub/brake disc to move back and forth independently of the brake caliper, this pushes the brake pads back away from the disc, so you end up with a longer brake pedal as the pads have to be pushed back into contact with the disc before they can start to slow the discs rotation.
It is a point, Scott.
However, when my 80 recently shot an original front wheel bearing (apparently to pieces and I was lucky not to lose the whole hub I’m told) I didnt feel a thing mechanically, only that the truck wanted to “wander” more than it should, no noises or clunks to suggest something wrong.
I did, however, notice an improvement in the responsiveness of the brakes, but only after the wheel bearing had been replaced. The pedal travel was marginally less after the fix, and the slight wheel wobble on braking that had crept up on me, was gone.
I find with our trusted trucks, that some problems generally develop slowly, and you adjust your driving to suit without realizing it. After repair, you can feel all the improvements, but they’re often not so evident as the parts deteriorate.
No complaints though, that wheel bearing was original (as still is the other side) and it had done 410k km. Can’t be bad can it?
I’ve just worked that out to be circa 160 million revolutions (if I’m any good at maths).
JMHO and crappy mathematics
