HDJ80 Oil Warning Lamp
Hi
I've just picked up a 1995 Toyota Landcruiser HDJ80 and wondering if anyone
can shed any light on a problem I'm looking to resolve.
When the engine warms up (after about 10 minutes running) and the revs drop
below 2000 rpm I get and orange oil can appearing on the dash. This seems
to be related to the oil pressure indicator as the warning lamp goes out
with increased oil pressure (engine revs above 2000 rpm).
The oil level is fine and there are no issues with engine temp.
I'm hoping this issue will be resolved when I change the oil but was
wondering if anybody could suggest any other areas to look at while I've got
the sump empty. Is there any easy way to check the performance of the oil
pump on these vehicles or are they hard to replace? Can't think of anything
else to check so any ideas welcome.
Brett Horwell
Tel: 077 3893 7470
London, United Kingdom
1995 HDJ80
Hi Brett
I have no experience of HDJ80 oil warning lamps, but I had similar case in
our old 30ft fishing boat with Leyland diesel from 70`s. When engine was on
idle oil lamp was glowing. Not as bright when just power was connected, but
glowing still. I asked about this from repair shop and mechanic told not to
worry. Tolerance of the pressure sensor just was so wide it gave signal even
when idling.
So maybe there is not any major problem with your LC. But I am not an expert
on this matter.
Cheers,
osku
Oskari Hellman
[Email address removed]
+358-50-5837050
Land Cruiser HDJ100 -98
255/85-16 BFG MudTerrains
OME 2" Lift
ARB Roofrack
Superwinch EP 9.0
On 21.1.2010 21:46, "brett horwell" <[Email address removed]> wrote:
ne
op
s to
h
ering
mp
to
Brett,
Your 80 may be running winter oil, which is thinner. Thinner but
it does get round the engine. With a thicker oil, such as a 15W/40 the
gauge may go out.
Clive Marks
Home: +44 1293 514600
Mobile: +44 7821 491897
Crawley, West Sussex, UK.
Hi,
It could be low oil pressure, change the oil is probably the first port of
call.
Big end Bearings it could be, but also it could be a dodgy oil pressure
sender or dodgy dashboard gauge.
You best bet is to rig a pressure gauge to where the oil pressure sender is
and see what the actual pressure is, check if it's in tolerance which can be
found in the workshop manual.
Manuals can be found online at http://daemon4x4.org/portal/downloads.php,
you will need a bittorrent client probably.
It could also be a stuck(open) pressure relief valve or loss of pressure
somewhere else in the system.
Let us know how it goes.
Martin.
Behalf Of brett horwell
Sent: 21 January 2010 19:46
To: [Email address removed]
Subject: [ELCO] HDJ80 Oil Warning Lamp
Hi
Brett Horwell
Tel: 077 3893 7470
1995 HDJ80
> Regards
> Martin.
Has it got a genuine Toyota oil filter? In the past, I can recall poor
quality filters affecting oil pressure.
Neill W
Neill Watson | +44 (0)7812 766760 | +44 (0)1642 781112
E: [Email address removed]
W: http://www.neillwatson.com - Photography
W: http://blog.neillwatson.com - Blog
W: http://www.drivingimages.com - Cars & Cameras
http://twitter.com/neillwatson - Twitter Page
Hi guys
Thanks for the emails. I'm still working on this one... Current thinking
is that it must be a dodgy sensor (at least I hope that's all it is) as
I've changed the oil and that hasn't sorted the problem.
The warning light that is coming on is supposedly only related to low oil
level (according to the Toyota Manual) and I know for certain that this
isn't a problem as it's sitting right on full on the dip stick. It does
seem odd that the warning goes out with increased revs (and a little
concerning) but I'm going to try replacing the sensor and see if that sorts
it out.
Will let you know if that resolves the issue, thanks again for the feedback.
Rgds
Brett
On Sat, Jan 23, 2010 at 1:04 PM, Neill Watson <[Email address removed]> wrote:
> Regards
> Martin.
> Regards
> Neill W
