Henri Stofberg from the LCCSA
Henri Stofberg
47
0
16
Musina ZA
Your name: Henri Stofberg
Your Cruiser: 80 1HDFT D/C
Mods on your Cruiser: This is quite extensive
Converted to Double Cab configuration
Replaced 3F with a 1HDFT Optimally tuned. 150kw 500nm
Intercooler
Replaced viscous fans with electric fans. (From a Toyota RunX)
ARB diff locks. Front and rear.
33" tyres
2" lift Ironman
Custom built Aluminium canopy
Custom built bins 15 in total
80l dual fridge. (Fridge freezer.)
28l water tank. In the right rear fender.(Building another 2 x 40l tanks that will go in next to the chassis)
270l diesel on board (custom built 180l tank)
Dual batteries. With selective dual control.
Custom intelligent voltage regulator.
Onboard 160l/min TMax compressor with 15l air tank. (Pressure controlled at 4-6bar)
Air helper springs in the rear.
Custom front bullbar with hatches for recovery gear.
Front mounted hi-lift jack
Mounted pri bar for real rocky problems.
Rear mounted spare wheel
Custom roof console. This also has a hidden compartment for forex when crossing borders. Also hosts aux power points and the 2-way radio.
Plans for your Cruiser: I think she is big and fat enough. Just ongoing fiddling with bins and such. Streamlining.
4x4 Experience: Done lots of overlanding and trails all over Southern Africa
Anything else you think is interesting or relevant: This big bitch is regularly called on when other mere mortals get in trouble.
Yes this is a brag. I am very proud of my Big Fat Bitch.
Andrew Prince
2,232
13
38
Joburg, sunny South Africa
Hello Henri and welcome to our site :mrgreen:
I've read many of your posts on LCCSA and I'm sure all of our members here will benefit from your extensive knowledge and experience!
It's good to have you on-board - now we just need some pics :whistle:
Cheers,
Andrew
AdBlock Detected
