Hydraulic winch pump
Hi,
Does anyone have experience of fitting a dedicated hydraulic winch pump on a
24v 80 fitted with air con? I want to avoid using the power steering pump
for the well known speed issues, but can not see where I can fit a belt
driven pump. I have considered the PTO option but think it will be too
expensive.
Ian Rubie
Hampshire UK
96 HDJ80 2.5" OME Lift
Ian,
When you say 24v I assume you mean the 1HDFT engine.
I've got a ZF pump fitted on the D/S of the engine block but I have no
air conditioning. Having said that, there was just enough space there
for me to sequeeze in a York air compressor. I think it is possible
to have the pump and keep the A/C compressorsor.
Rgds,
Roman (London, UK)
'92 HDJ80
On 6/3/06, Ian Rubie <[Email address removed]> wrote:
Hi Ian,
Occasionally people relocate the power steering pump reservoir and then
fabricate a bracket to mount on board air, etc there - I guess you
should be able to fit a small hydraulic pump there.
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
julian
into the final few days of preparation before heading to africa and
australia...so if you could unsubscribe me it'll save my hotmail box getting
full of answers to questions that i need to know the answer to when im stuck
in a ditch in Cameroon
Ive learnt a lot reading the posts on here..thanks to all the experts
chat when we return
regards
jeff& jean watts
www.gonewandering.co.uk
Thanks for the replies to my pump mount question. I think the way I will go
is to relocate the power steering reservoir as Julian suggested.
Ian Rubie
Hampshire UK
