Ignition voltage (Clamp 15) for daytime running lights
fittus
austria
Hello,
i have bought a pair of front fog lamps with an integrated led bar for daytime running lights for my Land Cruiser 100 (year of construction: 2006). The fog lamps and the led bar are independently to switch.
Is anybody out there, who can give me a tip, on how i can branch clamp 15 (it is the voltage which is switched by ignition lock). I will use this voltage for a relay to switch on the led daytime running lights automatically.
Today i have searched in vain for this branch point or cable. The problem is, that on the floor of the driver and passenger side there are present a lot of smal harness connectors, which gives no possibility to branch por it will cause in a failure. All is very narrow and inaccessible.
Also in the engine compartment i have not found an usable point/cable for an ignition voltage.
I don’t want use a manual switch.
Thanks for your help.
- fittus-
