Hi,
Is the car new to you (i.e. do you know if the centre difflock light has ever come on in 'HL') ??
I suspect you have a Limited Slip Diff at the rear instead of the electric locker that we can have in the UK.
Is the gearbox manual or Automatic ??
In the UK cars we have two switches on the Transfer Box on the manual versions and three on the Automatics.
1. = Centre Difflock engaged (works from difflock selector shaft).
2. = Tells the CPU that the Transfer Box is in Low Range (so it can engage the rear difflock if required and disable ABS). This works from the Low Range Selector Shaft.
3. = On Autos, it tells the CPU that the Transfer Box is in Low Range (I think it alters the shift characteristics). Also works from the Low Range Selector Shaft.
If your light used to work, but no longer does, I suspect someone has crossed the switch connections when doing some servicing. It seems that its showing the Centre Difflock to be engaged when its in Low Range.
If that is the case, something else should be happening when you move to 'HL' - does the ABS Warning Light come on ??
Or maybe the low range switch isn't connected to anything.
Interesting
Bob.
