Info re a Hilux purchase
Rodger
Yes, I know this a LC site but a few of you have Hiluxes, so I thought I'd ask first.
A good friend's son works in Zimbabwe on a lion reserve (Antelope Park) and he wants to buy a Hilux double cab. I suggested that he go to SA as that's where they are made but to bring it back to Zim is not as simple as it sounds - you can be stuck at the border for up to 3 days while the officials decide how much they think they can get out of you by way of import duty as there is no fixed rate and white Europeans are considered to be the best value. That is not an option for him, so he'll have to visit the main and only dealer in Harare but he's no mechanic so needs to know what he should be looking for....
He'll probably have to go for an earlier 7th generation or a late 6th. Diesels.
Unless he's very lucky, most trucks available will have had a fairly hard life, but what wears out and what gives trouble?
Your input, gentlemen, is appreciated
Mine isn't old or abused enough yet to give trouble
the front end is basically almost the same as a 120 series landcruiser, same engine and front suspension. Not sure if gearboxes are the same.
back is leaf springs of course.
I have not actually heard of any know issues with the post 2011 hilux
Some of the 2005-2010 had the same injector washer issues as the 120 series
