Just a heads up
Zeusv8
I've just had a coolant hose split open due to the steering rod at the bulkhead rubbing a groove into it and the other hose isn't too far behind splitting too so it's probably a good idea to go check where the hoses in your car are sitting, few cable ties will sort it for you if it's touching the steering rod.
On which vehicle?
They must be part of your LPG install? There are no coolant hoses in that area on mine ...
Yeah it looks like they were moved to accommodate the lpg but I think they are perished as well, as the second one just split as I moved it ! Anyone know the proper sizes or diameter for replacement and where to get them?? Thanks.
They will have T'd into the heater hoses near the bulkhead to install your LPG and the size used will depend on the installer and installation so you'll need to measure the ones you have.
Ok thanks for the help Jon, it's much appreciated. I had less trouble with my 97 surf than this gremlin infested cruiser!!
