- Feb 2, 2013
Last night when Helen was leaving for work she moaned about a noisy fan belt so i sprayed some wd40 on it which cured the noise and she left . Tonight as she's leaving to go somewhere she says oh the noise is worse now so i poured traffic film remover on the belts which stopped the noise and she left . Arrives home 15 minutes before she leaves for work and says its even worse now .
Quick play driving back and forth in the lane and the noise is definitely coming from the belt area , Helen has better hearing than me and says its coming from down low.
Then she decides to tell me the window wipers wouldn't work the other day and the alarm kept going off so she thinks the batteries are dead . Both tested over 12 dormant and over 14 with the engine running . Trucks gone so i'm sat here thinking belt tensioner is failing .
I don't have a manual for this truck but a search of roughtrax shows there is a tensioner and an idler pully on the KDJ so can anyone tell me which is the lower ?
Should anyone have any alternative thoughts the only other clue i can offer is that as i watched her drive off the noise put me in mind of an electric motor assisting acceleration .
