KZJ78 ATP light comes on when braking
acd2005
Hello All!!,
Yup I have a strange issue on my KZJ78 the ATP warning light comes on when braking...it will stay on for a bit sometimes while the brakes are are still applied and then go slightly dim and go off or if I remove my leg of the brakes the light goes off imediately....
Anyone seen this issue happen before?? Can I try to check something if there is like a short in the wiring somewhere??
Please help!!!
Have you checked the brake fluid level? If its low then it will be a sing that you have low brake pads or your loosing a little bit of fluid from the rear brake Cylinders.
