Landcruiser mods / Fuel additives - the answer
Marek Wojak <[Email address removed]> Wrote :-
snip "I run a K&N filter on my 80 with positive results, better engine
response."
Sorry Marek, but this thread had been bounced back and forth quite a bit on
the Birfield list.
It would appear that, for off-road, or dusty conditions, the K.& N. don't
work. Well, it does, but at what price?
I like the gen on the 'peswiki' site though. It ties in with what I know
about the Forte and the way it removes 'varnish' from injectors (acetone is
a varnish and paint solvent).
On the face of it, it's well worth looking into. I will certainly be doing
a little research myself as I know exactly what my cruiser does to the
gallon / litre. I've checked it religiously over the last 5000 miles.
Only trouble is I believe that 100% pure acetone is hard to get over here
in Ireland.
Thanks for the link.
Mik Kenney, (Cruisermik).
T.L.C.A. Member (Last 8 Years).
82 FJ 40 'Swagman'
97 80 1HD FT. 'Abe'
Hi Mik
Will see the long term affects on how the K&N filter performs with dust
I guess here in Aust with regular inspections.
As I have mentioned I have been running Acetone for a month or so and
will continue to do so due to the positive results.
I'm also a member of the Yahoo Acetone test group. I have seen many
positive tests carried out by members but there have also been some
concerns raised as well.
One issues raised are concerns the long term affects on engine lubrication:
http://pesn.com/2005/04/12/6900080_Acetone_Contraindicated/
Hence as with any experimentation one will need to keep a balanced
prospective .
Marek
Sydney
Oz
mik. wrote:
avast! Antivirus: Outbound message clean.
Virus Database (VPS): 0515-1, 12/04/2005
Tested on: 13/04/2005 8:07:31 AM
avast! - copyright (c) 1988-2004 ALWIL Software.
http://www.avast.com
prospective .<
Thanks Marek, I appreciate that acetone is a very strong solvent and
probably wouldn't do the engine oil much good.
(Do I take it you are now having second thoughts?)
As a matter of fact, I worked with acetone several years ago in connection
with the glass-fiber trade.
I promice, I won't do any jumping in with both feet till I've done a lot
more reading. Thanks for the new link.
82 FJ 40 'Swagman'
97 80 1HD FT. 'Abe'
Hi Mik
I will continue to use Acetone as the amount is very small and to date I
have seen positive results with power and economy increases.
I tend to keep and open mind and look at the all pros vs the cons hence
the link re lubrication.
Being a member of the acetone test group helps as results of tests ppl
have been conducting are also posted on the site.
An email response from LaPoint (he wrote the paper on Acetone in fuel)
who has been conduction tests for over 20 years is attached:
http://pesn.com/2005/03/17/6900069_Acetone/
"My 1964 Ford Econoline Ford Van ran over 20 years with acetone used
during all that time in the gas. Went 567,000 miles before the 80 below
wind chill froze the water pump on Dec. 16, 1989 in Saint Paul. When I
pulled the head, the cylinders had .004 to .007 wall wear. I had done
the valves in Wisconsin in 1983 but they did not really need grinding. I
just lapped them. The MPG averaged 26 on the road.
My 1995 Neon that is now 10 years old at 130,000 miles and runs with
acetone all the time. It runs perfectly. Absolutely perfect. Just
averaged 45 MPG IN TOWN last week. And just last weekend we averaged 50
to 73 MPG on a test run through Wisconsin with special mileage devices
attached. Never had engine work.
My 1990 Caravan ran great up to about 190,000 before the tranny went out
for the fourth time. Always with acetone up to 25 MPG. My 1997 Caravan
still runs great and has 130,000 miles on it.
Our 1996 Olds gets 25 MPG in town.
THE LIST OF OTHER CAR AND TRUCKS IS TOO LONG TO MENTION HERE.
All THESE cars have Torco Oil in them and Baldwin Filters and NGK plugs.
FACTS. Absolute true facts. My Scan Gauge does not lie and neither do I.
What data do these people show? Actual data. Actual test results.
Just for the record, it is gasoline in the oil that causes severe ring
and wall wear. Anything that reduces or eliminates fuel from the area of
the rings MUST reduce piston, ring and wall wear."
*Cheers
Marek
Sydney
Oz*
> >I have seen many
> lubrication:
> prospective .<
> connection with the glass-fiber trade.
> lot more reading. Thanks for the new link.
> 82 FJ 40 'Swagman'
> 97 80 1HD FT. 'Abe'
> European Land Cruiser Owners Mailing List
> Further Info: http://www.landcruisers.info/lists/
> avast! Antivirus: Inbound message clean.
> Tested on: 14/04/2005 9:20:09 AM
Marek Wojak
Project Manager
Sydney Metro Computers P/L
2 Colong Close
Hoxton Park, NSW 2171
Sydney Australia
Ph: + 61 2 9608 9706
Fax: + 61 2 96088209
Mob: 0438 181243
Email: [Email address removed]
Web: www.sydneymetrocomputers.com.au
WARNING: This e-mail contains information which may be confidential and subject to copyright. Please do not copy or forward this email to anyone unless you have the express permission of the sender.
If you are not the intended recipient,please delete the message immediately. Sydney Metro Computers Pty Ltd does not warrant or guarantee that this e-mail (and attachments) are free of errors, viruses or interference, or have been received in the form sent. The recipient assumes all responsibility for any consequences resulting from all uses made of this e-mail.
Tested on: 14/04/2005 9:41:16 AM
